Mazda bg hatch sohc auto to dohc manual conversion
Hey guys I got a 1991 Mazda bg ive converted from 1.5 sohc to 1.5 dohc injected I also went from auto to manual conversion . It's all in but won't start up the ecu and engine loome is from the donor car so I thought I would not have issues with tricking car it's in park. I'm trying to avoid changing dash loome is there a sensor or some wiring I need to do I'm not aware of. Any help will be great
Hmmm interesting as that ECU is OBD1 (up to 1995) so it is really on the "dumb" side as ECU were in that era?
So go the car cranking was a 3 pin plug that use to run to auto box and cut and twisted a red black and blue black wire now I'm getting crank.
New problem no getting fuel I'm about to check relay under ecu and change pump . Old pump worked fine but now won't prime have AFM hooked up no blown fuses so it's gotta be a relay ecu issue if not the pump I'm bout to change
schumiisking
Mar 1, 2007 07:08 PM
