Mazda 323 -95 doorpanel
Old Aug 30, 2006 | 03:36 PM
mazdaalpine's Avatar
Default Mazda 323 -95 doorpanel
Hi!
I just bought a mazda 323 -95!
I wanted to change my stock speackers at the front doorpanels!
But the funny thing is that i can't get the doorpanel off!
If anyone could send me a picture of how to get the doorpanel off i would be grateful! Lke which screws i should take out and so on and so on.OR just explain it to me! A picture would help me alot!
ANYONE!
Can't wait to get my new speakers and subwoofer in the car!!
Old Aug 31, 2006 | 07:23 PM
babyhuey's Avatar
Default RE: Mazda 323 -95 doorpanel
Here is the closest I could find. should be almost identical to your 95 323.
Take off cover piece at lower rear door corner to access a phillips screw.
There is another down inside the door pull hole.
One more at upper front cover under a small trim cover that should pop right open.
Last phillips screw is in the inner handle cavity. Pull inner handle out a little bit.
Once all of the screws are out you just need to pull straight outward to release all eight plastic clips along the bottom and sides. Once the panel is loose then lift upwards to get the upper pins out of the door sheet metal.
[IMG]local://upfiles/1377/95BBE2357B4A46CFAE967A65DA58A370.gif[/IMG]
sphincter
Jul 21, 2006 09:04 PM
