Mazda 323 '00 Idle adjustment
Old Nov 11, 2024 | 06:30 AM
Lucass2T's Avatar
Default Mazda 323 '00 Idle adjustment
Good afternoon everybody,
My name is Lucas, from the Netherlands and I own a 2000 323 BJ with the 1.5L ZL engine.
The car has 165.000km (just over 100k miles) and is in a very good state of maintenance.
It's idling at around 600 rpm which is too low.
it is objectively too low and it also feels like it's just a tad below where it is happy at.
I tried adjusting the idle according to the procedure explained in OEM mazda workshop manual.
It says, connect a wire to GND and TEN on the diagnostics port which puts the ECU is some sort of maintenance/adjustment mode I assume.
Then adjust idle to desired rpm and after that remove the wire again.
After I adjusted the idle to my liking (around 800rpm) and removed the wire as described, the rpm dropped again to earlier value.
When I connect again rpms go up again to the adjusted value.
But It doesn't want to stay at 800 without the wire connected.
What am I doing wrong here?
Old Nov 11, 2024 | 09:41 AM
Lester26
Dec 21, 2020 01:25 AM
AziDahaka
May 22, 2020 03:07 AM
Stihl070
May 16, 2019 08:31 PM
323GTS
Feb 19, 2010 09:25 AM
Thor_k06
Aug 29, 2006 01:25 PM
