general advice: new fuel pump or no?
Old Nov 17, 2012 | 05:57 PM
berninicaco3's Avatar
Default general advice: new fuel pump or no?
Digging into our 1989 mazda 323 for some maintenance, we found OH so much rust.
Including the fuel tank, which was leaking from a corner and had a visible rust opening in the top, as well.
*sigh*
We're hugely overbudget. This was supposed to be an $800 overhaul and now it's hitting $1500, with broken springs, a rusted-through trailing arm, a sensor or two, the fuel tank... it adds up, and there's a lot that really wasn't apparent just looking around with a flashlight, before we started tearing things apart.
Do you recommend, since we're replacing the tank anyway and therefore removing the fuel pump, replacing the fuel pump too?
The vehicle has only 64,000 miles, so the pump is original manufacture, and low mileage, but, 23 years of age. It still works fine at the present. In your experience though, is it wise to spend the $80 to get a new aftermarket pump as insurance, have you seen pumps fail from age alone? Or, do they only fail from miles (worn out) and debris sucked through the pump, and the aftermarket might even be worse than the OE?
I'd feel like an idiot if I don't replace it, and I have to drop the tank again next year if the pump gives up the ghost.
At the same time, we're running out of funds, and if I don't need to spend the $80, you haven't seen low-mileage fuel pumps fail from age in your experience, then, I won't.
Thanks for the advice!
-Bernard
Old Nov 18, 2012 | 01:01 AM
MazdaTirol's Avatar
Since your already at 80% of the work needed to change the pump I would just change it, nothing like getting your car back together with a full tank of fuel just to have the pump die in 3 days. Also mileage doesn't mean much on a pump its the hours its been running and its how its been used or abused, if the tank has been run low (less than 1/8th) consistently then the pump can overheat due to not being submerged in enough gasoline for cooling and wear out faster. If you have rust on the outside of the tank there is a good chance the inside is rusting out too and the pump may have ingested some of that if the sock on the pickup tube is gone. I know how much part prices can hurt when your on a budget but some things are worth going the extra mile for, I dont have to replace my lower balljoints on my 323 but since I have to change my CV boots I am doing the balljoints now, same amount of work for both, why not do it now and not next year.
06Tungsten6
May 26, 2011 09:37 AM
Variety=Spice
Oct 11, 2007 11:14 PM
CardsFan420
Nov 8, 2006 06:25 PM
purpleham
Feb 21, 2006 02:25 AM
bkey71
Sep 20, 2005 11:37 PM
