ECM Diagnostic Port - HELP ?
Hello
I cannot seem to get the ECM Diagnostic port to work That is, read out the OBD-I codes. I have a: - Mazda 626 93 Automatic Australia Does not have a CEL (Check Engine Light) on the Dash. Method: - 1) Located Diagnosic Port ( See attached image ) 2) Connected TEN (Test Engine) to GND (Ground) on Diagnostic connector. 3) Connected FEN to 12V Test Light and Ground on Diagnostic connectr. 4) Turned Ignition Key to ON. -> Nothing happens ie. no 12V Test Light activity Any help here would be appreciated. Thanks [IMG]local://upfiles/19890/A85819C178F140A4B545E4D1EEE4C62A.jpg[/IMG] |
RE: ECM Diagnostic Port - HELP ?
That one has another diagnostic connector. It uses the ford type. Autozone should have the hookup for it. It is also under the hood.
