Clunking Sound--HELP!
My 1998 626 has developed a continuous clunking sound on the drivers side, front. It does not do it under acceleration, but when you let up on the gas. Is this a CV joint problem? I've only owned the vehicle for one month and this just started.
Thanks,
QT Band
Thanks,
QT Band
Check to make sure that the caliper and caliper mount bolts on that left front corner are all there and tight. A CV joint could be causing the noise but noise from CV's are usually most predominant on a light accel when turning hard to one direction or the other at low speeds.
shenga
Mar 17, 2008 01:03 AM
