94 Mzda 323 Head Gasket Symptoms / Replase?
Old Aug 1, 2010 | 04:41 PM
VooDooMan's Avatar
Default 94 Mzda 323 Head Gasket Symptoms / Replace?
Hey fellas,
Done lots of lurking here......Thought I would finally register and post my newest issue.
Just bought this 110K mazda 323. my other one headed for the scrapper.
First thing I noticed is a massive amount of dried and dirty oil all over the motor. Hot water washing + a couple cans of engine cleaner solved most of it.........a small tune up and a 20 minute drive later I noticed lots of oil pouring down the joint ( where the engine mounts and meets the tranny.
I followed it back up to JUST under or around the corner of the head. Nearest the distributor cap. The hard head gasket is poking out a tiny bit and I see it cracked. Oil is draining from there - At least I think so.
I don't know this history of this car but it seems well kept. No real signs of engine over heating causing a crack or warp in the head as far as I can tell........But what do I know - this will or would be my first head gasket replacement.
Can any one confirm what I am seeing here?
Could the oil be coming form another source? I have no heat issues or oil coolant mix or any thing of that nature......Just friendly old oil ! lol
Pictures if need be........Thanks!
Old Aug 1, 2010 | 04:58 PM
VooDooMan's Avatar
http://img839.imageshack.us/f/house032.jpg/
http://img828.imageshack.us/i/house031.jpg/
Old Aug 1, 2010 | 09:00 PM
VooDooMan's Avatar
Oil is running down the engine core.........vertically down as in picture 31 - Start in the corner at the gasket and runs all the way down, heavy leakage.......Any one?!?!
Thanks
Old Aug 1, 2010 | 11:29 PM
VooDooMan's Avatar
http://img829.imageshack.us/f/dizy001.jpg/
Heavy oil spot in corner......long oil leak.
Camon guys!
Old Aug 3, 2010 | 08:33 AM
athomas1469's Avatar
voodooman,
i looked @ your pics and i was kind of confused about what i was looking at. anyway it sounds like your valve cover gasket is leaking & not your head gasket.
Old Aug 3, 2010 | 11:32 AM
Gimme3Doors's Avatar
Yep, I found the pics confusing also. And I'm also thinking it's the valve cover gasket. It's a common failure and source of oil leaks.
Old Aug 3, 2010 | 11:39 PM
VooDooMan's Avatar
thanks for the infos guys........its 100% my head gasket not my cover.
any picture guides on how to remove and replace the gasket?!
Old Aug 7, 2010 | 01:26 AM
tireboy's Avatar
valve cover gasket and the disty o ring...
BogusSVO
Feb 1, 2013 11:37 AM
dnjsdad
Sep 4, 2007 12:46 PM
spiderpig
Aug 12, 2007 10:47 PM
!Gn|T|0n
Jun 12, 2005 03:31 AM
