93 626 check eng. light
Old Sep 2, 2007 | 02:27 PM
wldturkey76's Avatar
Default 93 626 check eng. light
i have a 93 626 . check engine light is on giving a cam position sensor trouble code when checked by a jumper wire in diagnostic box under hood(according to instructions in Haynes Manual) car idles rough and lacks powerwhen cold but seems mostly ok after warm up.i have put in NEW dist. ,cap ,rotor, wires. plugs, and coolant temp sensor. still same trouble code. when hooked up to code reader it gives code, NO DISTROBUTOR PICKUP. not sure what that means. have tried to reset check eng light with no success.check englight comes on about 10 seconds after startup. can anyony help??
thanks
Old Sep 2, 2007 | 09:19 PM
hixx's Avatar
Default RE: 93 626 check eng. light
I would check the timing belt to see if it has jumped a tooth. Otherwise the distributor houses everything. They are kinda bad about eating distributors and usually take the catilytic converter with them.
indranghimiray
Jul 28, 2010 04:53 AM
Ternigh
Jul 27, 2009 08:04 PM
palunga
Aug 18, 2007 09:59 AM
hawaiiboy
Nov 9, 2006 10:39 PM
Desmus
Sep 8, 2005 05:07 AM
