89 323 Manual Trans Problem
Old Mar 17, 2008 | 02:20 PM
spoil_kid123's Avatar
Default 89 323 Manual Trans Problem
Hello people,
My clutch started to slip so I decided to changeit myself. However after removing the Manual Transmission I noticed that gear oil was leaking.Theoil seal on theManual Trans was leaking. I was able to change the seal myself with no problem although having to actually dismantle the Trans.
I installed a new clutch and put everything back together. Iwent for a test drive and it worked perfectly. After about 15 mins of driving I was not able to get 2nd, 4th and reverse gears.
So this is my problem.All up gears 1st, 3rd and 5th works fine butall down gears 2nd, 4th and reverse only works sometimes.
There is a 12mm bolt under the trans that I think needs to go into a groove of some sort, I think this is my problem.
Is there anyone who has some pics showing where this bolt goes.
However if you think that my problem issomething other than this please advise.
elcordovez
Jun 13, 2010 12:52 AM
Max EGT
Mar 23, 2008 09:06 AM
mazdamx6mm
Nov 16, 2007 08:22 PM
chassisguy
Mar 17, 2006 10:55 PM
blueman
Jun 12, 2005 03:26 AM
