626 misfire #1 cylinder.
Old Jan 6, 2018 | 08:55 PM
Bnoland's Avatar
Question 626 misfire #1 cylinder.
1998 626 LX 2.0 L4 165,325 miles.
After starting, engine running rough and smoking out of exhaust. All 4 new spark plugs were sooted up. Trouble code was misfire #1 cylinder. Switched #1 & #2 plug wires and ran worse with trouble code misfire all cylinders. Switched back and ran better with misfire #1 again.
Recently replaced the timing belt, both bearings, spark plugs, water pump, and used coil pack from junk yard to fix back firing in the exhaust. Coil pack was the problem and not timing belt. Ran fine for 2 weeks.
Need help with my latest misfire issue,
Old Jan 10, 2018 | 05:23 PM
Bnoland's Avatar
Did not receive any replies to my request but did use the older "posts" to develop a plan to troubleshoot the repair.
Replaced the junk yard coil pack with a new "coil pack" and that fixed the misfire #1 cylinder. Also cleaned the throttle body and MAF sensor with the correct chemical sprays while I was at it. Mazda runs fine now!
dyno
Mar 11, 2009 09:02 PM
01MPV
May 17, 2007 01:44 PM
MrMan
Jan 24, 2007 06:08 AM
KuroRyu256
Jun 23, 2006 10:50 PM
JJ
Apr 30, 2005 10:39 PM
