2002 Mazda 626 LX 2.0l MAF test
My 626 stalls sometimes when slowing down to stop. Im testing the MAF sensor with a multi-meter and im not sure how to interpret the results.
Test 1 Pin A 12V power on the MAF connector,multi-meter set to 20V DC. Key on Red lead to pin A, Black lead to neg. terminal on battery. should be 10 to 12 V
and it 12.64V GOOD
Test 2 Pin B grd. key off, multi-meter set to 20V DC, Black lead on pin B, REd lead on pos. terminal on battery. should be 10 to 12 V. and it;s 12.64V GOOD
Test 3 Pin C Signal grd. key on, multi-meter set to 20V DC, Black lead on pin C, Red lead on pos. terminal on battery. should be 10 to 12 V. and it;s 5.9V first test then
6.87V second test. NO GOOD.
Test 4 Pin D MAF Signal .MAF wire connected to MAF sensor, car idle, multi-meter set to 20V DC, Black lead to neg. terminal on battery, Red lead to pin D. should be 1.5 to 1.8 V. and it;s .84V NO GOOD
When I increase the rpm's the voltage goes up then down when i decrease the rpm's. Voltage seems the flow smoothly in relation to the rpm's.
Is my MAF sensor bad???
Any and all help greatly appreciated.
and it 12.64V GOOD
youngstah
May 13, 2009 05:40 PM
theguy
Dec 15, 2006 12:00 AM
