1997 626 won't start
Old Aug 13, 2009 | 02:59 PM
BRONIC's Avatar
Default 1997 626 won't start
Hi my 97 626 2.5 v6 wont start. I just replaced the head gaskets and timing belt and put the engine back together. Now the engine wont start, It will just turn over, It is getting a spark but the fuel pump isn't turning on. When i jumped the fuel pump using the diagnostic box in the engine compartment it turned on but the engine still wouldn't start. does anyone know what the problem might be?
thanks
-Brock
Old Aug 15, 2009 | 07:59 PM
neilh's Avatar
Default tb
i would check the valve timing again..you have to be dead nuts on all the cam and crank alignment marks with the crank at TDC and cylinder one on TDC....if the fp isnt turning on check the collision switch in the rear passemger compartment...1st check for 12 volts to the pump
Old Aug 16, 2009 | 11:26 PM
BRONIC's Avatar
I have checked the cam and crank alignments multiple times and they are all dead on, Also I was told by someone that the 97 didn't have a collision switch, if it does where exactly is it? and do you know where I can check the voltage going to the fuel pump, I'm not sure which wire in the engine compartment is the one for it.
tmj_ac
Jan 30, 2009 12:04 AM
greggstonecipher
Mar 30, 2007 11:17 AM
fatpelt
Nov 13, 2006 01:35 AM
NewGuy181
May 14, 2006 03:44 PM
blairham
Feb 28, 2006 02:07 AM
