1992 323 Sedan Fuse Box Diagram - speedo
Old Apr 10, 2006 | 10:07 PM
Skinner's Avatar
Default 1992 323 Sedan Fuse Box Diagram - speedo
Hello there,
The speedometer has stopped working in my 92 323. I suspect the fuse
has gone but, as it's a Japanese import the under dash fuse box cover
is Japanese characters.
I'm specifically looking for which is the speedo fuse but a scan or diagram
showing everything would be much appreciated.
Cheers
Skinner
Old Apr 10, 2006 | 10:31 PM
babyhuey's Avatar
Default RE: 1992 323 Sedan Fuse Box Diagram - speedo
A 92 323 should be a purely mechanical system unless Japan product has a digital display or something. If it is a standard needle speedometer then you have a driven gear in the tranmission that rotates the internal portion of the speedometer cable which is then mechanically connected to the speedometer. No electronics involved except a bulb to light it up at night.
Try taking the cable off from the transmission end and turning by hand while someone watches the needle for flickering movement. Do not remember if cable needs to be turned clockwire or counterclockwise but am thinking counterclockwise.
Old Apr 10, 2006 | 10:48 PM
Skinner's Avatar
Cheers mate,
I'll check that out, but I was sure it was electronic.
I'll check it soon and let you know.
Skinner
Old Apr 10, 2006 | 10:56 PM
Skinner's Avatar
Yes, you're correct, it's cable driven. I must have been
thinking of my old Nissan which was electronic.
Cheers
Old Apr 16, 2006 | 09:13 PM
superman_jjs's Avatar
Let me know where you find a replacement.
Thanks,
eliko963
Jan 19, 2009 11:50 AM
sonnybungay
Sep 20, 2007 01:39 AM
bart_man
Apr 9, 2007 09:26 PM
kasper
Jan 4, 2006 01:11 AM
khaosx2005
Nov 9, 2005 08:45 PM
