1991 Mazda 626: Starter Motor Fails When Engine Hot
Old Sep 16, 2007 | 06:33 PM
mazdawoes's Avatar
Default 1991 Mazda 626: Starter Motor Fails When Engine Hot
I have a consistent problem with a 1991 Mazda 626 Automatic, Fuel Injected, Turbo.
The car starts like a charm and runs well on a cold start.
If the car has been run for more than about 5-10 minutes, and the engine is stopped, the car will not start again. I have to wait several hours (usually) until I can successfully start the car again.
When turning the key, I hear the main relay click, but nothing else happens. There is absolutley no response from the starter motor.
The starter motor / solenoid have been replaced twice. However, the problem persists.
Old Sep 16, 2007 | 08:28 PM
hixx's Avatar
Default RE: 1991 Mazda 626: Starter Motor Fails When Engine Hot
It is a pretty simple circuit. 12 volts runs from the ignition switch through the inhibitor switch ( range selector switch on the trans) and straight to the starter. A 12 volt test light,a phillips screwdriver,a friend and 10 minutes should find the problem. Typically a no starter engagement hot is the starter but i presume the starter has been thoroughly checked out. Make sure the main wire from the battery and ground to the block are secure and free of corrosion.
ErikSchempp
Jun 4, 2012 07:27 PM
vladi.sama
Aug 22, 2011 03:22 AM
Pochi09
Aug 3, 2010 05:11 PM
twitme
10
Aug 27, 2007 12:12 PM
tjacorn
Aug 14, 2006 11:25 PM
