THROTTLE POSITION SENSOR
Old Jan 22, 2007 | 11:14 AM
rooster2's Avatar
Default THROTTLE POSITION SENSOR
What is the ohm reading for the throttle position sensor - 929 Mazda 1994. Which 2 pins do I put the test leads on? Has4 pins top(close to hood) bottom (close to manifold). Reason for adjustment: I loosened the 2 screws on the sensor andmoved it. Do not know if it is back where it was. Put it back close, but car did not shift right around 50mph.Loosened screw and moved it again. Shiftsokay, but would like to know how to get it back as it was before I moved it first time. Thanks, Rooster2
Old Jan 24, 2007 | 09:21 PM
babyhuey's Avatar
Default RE: THROTTLE POSITION SENSOR
Adjustment of the TP is actually done by voltage but normal range is too great for proper adjustment. You actually want to set the adjustment of the idle switch. Unplug the TP and hook up your ohmmeter to the two pins that would have the Black w/light greenstripe wire and Brown w/ black strip wire hooked up to them if connector was plugged in. You should have continuity thru these two pins with throttle closed. Now put a .004" feeler gauge between the throttle lever and throttle stop screw. You should still have continuity. Replace the .004" feeler gauge with a .008" and you should have no continuity. Adjust the TP as needed to get those results and you will be rightback to OE setting.
Old Mar 30, 2013 | 06:32 PM
adlerv70's Avatar
Baby Huey,
Is there a similar procedure for a 97 protege LX 1.5L MTX? I already messed with that screw before I knew not to.
Yogi_12
Aug 25, 2009 01:43 PM
ravensoul567
Dec 30, 2008 06:59 PM
chisan
May 25, 2008 01:59 PM
nitz
Mar 20, 2006 09:54 PM
Spunky
Jan 3, 2006 04:01 AM
