tech support, please
Old Jan 27, 2007 | 03:26 PM
ani's Avatar
ani
Default tech support, please
Hello
I'm new here and I'm very glad that I found out about this site because I do have a headache about my car right now, I've got Mazda millionea (SW), 2000. I do believe that you would have called it "Sport edition". The engine light came on and it started choking like it was drawning or something. I had my mechanic checked the light which said " Missed fire No. 2". He checked in detail and telling me that I have to change to fuel injector NO. 2 because it was plug up. I ordered the part from Hiroshima, he put it in for me and here we goes again, the light came back.
Does anybody have any idea what is going on right now? I will appreciate it so much, I paid a fortune for shipping and parts plus labor. This is the first time of me for Mazda, I've heard about it that why I wanted to give it a shot. Thank you very much.
Old Jan 27, 2007 | 10:47 PM
pickral 123's Avatar
Default RE: tech support, please
A miss fire code would mean to me that a spark plug did not fire on time. This could also mean a bad plug wire. I don't think I would have replaced an injecter, but since you have add some fuel injecter cleaner to your fuel. You did'nt say how many miles you have on your car, but I would change plugs and wires. Reset your ECU by disconnecting the ground cable from the batterey and pump the brake pedal several times.Reconnect the ground and you should be ok.
Old Feb 11, 2007 | 11:30 AM
eric83's Avatar
I have a1999 Protege ES 1.8L 104,000 miles with a P0420 code. What is the most common cause for this code. Car runs good and is getting good gas milage, but the check engine light is on. I don't have a clue where to start. After cat sensor or replace cat?
Old Feb 11, 2007 | 03:19 PM
mmt's Avatar
mmt
99% of the time, replace your #2 coil and sparkplug
Old Mar 11, 2013 | 06:48 PM
Perry twin cam's Avatar
Hey im new to this , i have a 1.8 twin cam 1996 motor out of a miata i was thinking on putting a webber kit on it dont want it to be fuel injection is there an complete kit selling some where that i can order this please . Do any one out there can help me thank
Old Mar 14, 2013 | 06:28 PM
Ravens706's Avatar
Default Windows stopped working
I have 02 millennia. The passenger window and the rear windows stopped working they will not roll up or down. Drivers side window works just fine. Lock is off. Fuses look good. When you push the switches for the windows that do not work the lights on the switches flash. Any help would be great
Old Apr 24, 2013 | 08:58 PM
adolfo1's Avatar
I am new here in this forum, I am on the road of learning the knowledge of Mazda, hope someone else can help you
Old Apr 25, 2013 | 07:47 AM
tanprotege's Avatar
Take the door panels off, inspect the wiring, motors and the regulator mechanical parts. If yo are lucky some cleaning and lubricating will revive them. If you are unlucky you need new (used?) window regulators.
SKINNEDR
Jul 27, 2007 10:57 PM
pkeddie
Jul 9, 2006 11:04 PM
turbo_miata20
Jul 8, 2006 08:57 PM
Spaz218
Feb 24, 2006 11:03 PM
mydogduster
Oct 19, 2005 12:00 AM
