Tachometer help
i have a 94 mazda 626 4 cyl. i recently bought a sunpro 5in tach with shift light but i cant find the ignition coil, where would i hook that up, directions for the tach say to go to the ignition coil, has anyone else put an aftermarket tach in their 626 that could help me out?
RE: Tachometer help
The coil is inside the distributor. The green wire is for the tach.
RE: Tachometer help
now do i have to take apart my distributor or is there a way i can connect that wire without taking apart my distributor, there are a couple of wire harnesses that plug into it, is that green wire one of them?
RE: Tachometer help
There will be a green wire going to the distributor you can connect to.
