Salvage yard transmission
Old Aug 22, 2015 | 11:54 AM
deleof's Avatar
Default Salvage yard transmission
Thanks for your help in advance. I have a 1998 626 with a four-cylinder, automatic transmission. My transmission was bad so I swapped out my transmission with a salvage yard transmission. I put in 2 gallons of fluid, and I turned on the car, shifted into each gear for a few minutes with the parking brake engaged to get the fluid into the transmission completely. But the car will not engage into any gear. I thought that maybe I put too much fluid in so I drained it a little bit, but that didn't help. I am wondering if I bought a bad transmission or if I have done something incorrectly. Any suggestions are greatly appreciated.
Old Aug 23, 2015 | 04:43 AM
Did you use your old torque converter? or 1 that came with the replacement trans?
Have you checked the fluid level on the dip stick?
Have you bolted the torque converter to the flex plate?
Are the axles & CV joints turning?
Old Aug 24, 2015 | 10:21 PM
deleof's Avatar
GR, yes I used the torque converter that came with the junk yard tranny and it is bolted to the flex plate. The axles and cv joints are turning. When I check the dip stick the fluid was way above the max level. That is why I drained some fluid. Any ideas?
Old Aug 25, 2015 | 06:55 AM
The fluid needs to be checked with the engine running & trans in Park.
Old Aug 25, 2015 | 10:01 AM
deleof's Avatar
That is the way that i checked it..."with the engine running & trans in Park". And the fluid was way above the max level on the stick.
Chris X Rice
May 20, 2014 09:08 PM
nkoski
Mar 17, 2013 09:48 PM
bcsumaya
May 13, 2009 06:20 PM
dam195_9
Apr 17, 2006 06:10 PM
blueman
Jun 10, 2005 09:36 PM
