removing backseat on Mazada6 wagon
Old Mar 19, 2007 | 12:25 AM
cksy's Avatar
Default removing backseat on Mazada6 wagon
does anyone have a suggestion how I can remove the bottom part of our backseat so I can look for small (usually sticky and decomposing) items carefully deposited by my children into the seatbelt openings?
Thank you,
CK
Old Mar 19, 2007 | 05:08 PM
babyhuey's Avatar
Default RE: removing backseat on Mazada6 wagon
On the front bottom of the seat cushion areas where the cushion meets the carpet you will see four square plastic triim covers. The trim covers are actually over the carpet area and not bottom cushion. Pop these little trim covers off by pulling straight outwards. Underneath you will find a 10mm bolt. Remove these bolts (two for each side seat ), lift the front edge of the cushion and you will find that the bottom cushion will neatly hinge upward to allow easy access for removal of all sorts of lost treasures.
Old Mar 20, 2007 | 01:28 AM
cksy's Avatar
That is fantastic - I was almost ready to take a torch to the seats but yours is a much better solution. many cheerios and gummy bears were discovered lurking beneath.
Thank you!
cluelessgirl
Feb 17, 2010 10:00 PM
Kasstastrophy
Jan 24, 2009 05:12 PM
Mazda929Driver43525
Mar 13, 2008 11:28 PM
ironbutttad
Nov 29, 2005 10:05 AM
