need help w/door panel removal
I have a window that goes up and down, but only halway. The motor and switch obviously work. How do I remove the door panel to see if a bolt needs to be adjusted? I can't find but 1 screw in the door handle area. Mazda 626 1994
Hello,
First of all, pardon my poor English...
The second screw should be located at the bottom of the (I don't know exactly how you name it in English) let's say "compartment" (the empty space within you grab with your fingers to close the door)...
You have to lift somehow the inside bottom rubber (It's glued) : the screw is hidden below the rubber
Hope this helps...
Best Regards...
Hope this helps...
Best Regards...
