NEED HELP ASAP!!!!
What kind of noise?? A clicking type noise only on right turns is a good indication of failing left outer cv joint. Look to see if the boot is torn open and spraying grease all over the place
Listed labor time for a shop to replace is around 1 hour. Fairly easy job to do. Remove both bolts between the strut and steering knuckle assembly, remove outer axle stake nut, drive axle out of steering knuckle/hub, pop axle out of transmission and install a remaned axle. The axles do sometimes really stick in the hubs and can sometimes be difficult to remove from transmission as access is somewhat limited.
