mazda3 axela bank 1 to rich at idle HELP!!!
Old Mar 17, 2012 | 11:27 PM
jugaknot's Avatar
Default mazda3 axela bank 1 to rich at idle HELP!!!
my check engine light keeps coming on showing bank one to rich at idle. its causing a drop in acceleration an gas mileage. i have a cold air intake, but didnt have problems until recently. ive tried a new mass air flow sensor, and running seafoam through the fuel system to clean out the carbon build up, but no permenant results. PLEASE HEEEEELLLLLLPPPPP!!!!!!!!!!!!!!!!
Old Mar 18, 2012 | 07:04 PM
jugaknot's Avatar
still needing help! was hopeing someone on here could help
Old Mar 18, 2012 | 09:56 PM
shipo's Avatar
As a suggestion; yank the CAI and put the factory intake back on, then replace or repair the wiring harness which has probably been stretched by having been rerouted.
Old Mar 20, 2012 | 08:25 PM
jugaknot's Avatar
ok,thanks. only problem is i dont have the factory intake anymore!!! and another question,why would it just start this even though the intake has been on there over a year?
Old Mar 21, 2012 | 05:31 AM
shipo's Avatar
The extra stress on the wiring took a while to compromise the electrical integrity of the circuit. As for the factory intake and wiring harness, you can probably pick them up at a junk yard for cheap.
Old Mar 21, 2012 | 04:34 PM
jugaknot's Avatar
ok thanks,ima try that and let you know how it goes. again thanks for your help!
Old Mar 21, 2012 | 04:42 PM
shipo's Avatar
Cool, be sure to let us know how you make out.
Old Mar 21, 2012 | 05:28 PM
If it's hi mileage, it could be leaking injectors.
Old Mar 22, 2012 | 04:29 PM
jugaknot's Avatar
Ok,so that could also cause the cutting out when i take off? And a drop in fuel mileage. is there any special way to test them or just start replacing?
Old Mar 22, 2012 | 04:51 PM
shipo's Avatar
While I'm not saying it isn't your injectors, I find it highly unlikely to say the very least. The thing is, modern fuel is so well fortified with additives and detergents that, contrary to popular belief, fuel injectors rarely "leak" or have other issues.
As I said before, your issue sounds very much like an electrical short caused by the torque from your engine pulling on the wiring harness, which was in turn caused by the installation of the CAI and the rerouting/stretching of the wiring.
