Mazda 2 Starting Problems
Old Oct 4, 2017 | 02:43 PM
RossG's Avatar
Default Mazda 2 Starting Problems
Hello everyone.
Over the past few weeks, I have noticed a problem when starting my Mazda 2. It produced a number of clicks before starting up. Eventually the car wouldn't start one day when I was at work so after speaking to the breakdown mechanic, he said that it was the alternator causing the problem as there was not enough charge going to the battery. I changed the alternator which fixed the issue temporarily but noticed that after a few days, the car still wouldn't start. I bought a new battery and again, the car ran smoothly for a couple of days but now I'm having problems again.
When I turn the ignition, there are a number of clicks heard for around 4-5 seconds.
The headlights dim occasionally when driving and also dim when using the electric windows.
Ideas anyone?
Ross
Old Oct 4, 2017 | 05:39 PM
Check for current draw, which could be draining the battery.
Old Dec 5, 2019 | 01:33 AM
Jeff Jackson's Avatar
Default Jeff Jackson
Originally Posted by RossG
Hello everyone.
Ideas anyone?
Ross
Got same problem, did you get it sorted
Old Apr 5, 2021 | 06:11 AM
awhale's Avatar
Hi - I had a similar problem. When trying to start the car there were clicks coming from the starter motor. After several days, the car refused to start, making just one clicking noise. The rest of the electrics then just died. After a while the electrics came on again. I tried to start it again, but just one click and the rest of electrics just died again. I replaced the starter relay, but that didn't fix it. I was convinced it was the starter solenoid, but I decided to connect a jumper cable from the battery negative to another point on the car body. The car started! This pointed to a bad earth from the battery to the car body. I removed the battery and located the point where the negative cable attached to the body. I unscrewed the rusty connector, cleaned it up and used emery on the body to ensure good contact. Connected it all up and problem sorted!
I hope that helps others
All the best.
rubenreyes
Jan 12, 2017 09:42 AM
candi
Nov 29, 2014 01:34 AM
acreu61
Jul 17, 2014 03:51 AM
getfawaz
Sep 17, 2012 02:32 AM
mhhh0107
May 2, 2011 12:36 PM
