I put my battery in backwards
Old Oct 3, 2007 | 07:29 PM
jacobspoor's Avatar
Default I put my battery in backwards
Yeah so im an idiot and put my new battery in my car backwards wich blew three or four fuses I fixed them but my car still wont start when I turn the key I just hear it click. Any one have an idea on where I should start?????
Old Oct 4, 2007 | 08:11 AM
hixx's Avatar
Default RE: I put my battery in backwards
Start at the starter,check for 12 volts cranking.( probably 10 volts with voltage drop) If no voltage there go to the ignition switch and trace from there. Check all grounds/connectors for overheating etc.
Old Nov 7, 2007 | 08:18 PM
Mazda305's Avatar
So you put your Battery in wrong i am guessing you have it fixed by know. But just wanted to have my input most likely the battery lost its charge as you sent power through the system the wrong way. but it would be intresting to see what the problem was so let me know
GopherInWI
Oct 11, 2025 08:51 AM
tye
Dec 9, 2023 10:05 AM
rbearden
Jun 26, 2021 03:21 AM
Gateway Lady
Nov 26, 2012 11:18 AM
kbaby77
Nov 2, 2008 04:20 PM
