-   General Tech (https://www.mazdaforum.com/forum/general-tech-6/)
-   -   Help, Mazda protege Idles way too low! (https://www.mazdaforum.com/forum/general-tech-6/help-mazda-protege-idles-way-too-low-5275/)
dank Oct 25, 2006 12:52 AM
Help my 91 protege 1.8L 5spd (170,000 mi) runs great but idles way to low. when coming off the highway and i step in the clutch the idle speed drops so far that the engine sometimes dies. If it does stay running it will idle around 200rpm. When its cold in the morning it idles quite well around 600-800 rpm.
This past summer when it was quite hot out it would idle just the opposite..way to HI sometimes 1800 to 2500 rpm..when the engine was hot.. When it cooled a bit it would idle around 1000-1200 rpm.
Any ideas....Air flow meter? some other adjustment?
THanks for the help!!!
Sirob Oct 25, 2006 04:37 AM
RE: Help, Mazda protege Idles way too low!
If I am not mistaken, the idle speed drops when you depress the clutch pedal and shift to neutral. If so, please note that we had similar problem with one of our European 626 in the past. The problem was defective neutral switch. You may therefore wish to check the neutral and perhaps the clutch switch as well.
Please also visit http://protege5.ugly.net Although the site is for 2002 it may help you to locate the switches etc.
