HELP on AC
I used compressed air to unclog the AC drain tube on my CX9 with compressed air, now the AC Fan and Air does not blow out of the Dash but the rear does.
WHY? What happened? How can I fix?
Doesn't sound related, maybe just bad luck.
If you try the fan at each speed from low thru to high, do you feel any air coming out any of the front vents?
Failing that, try swapping the relays around and see what happens. Its possible for the fan to die. You would need a multimeter to test it. Also its not far fetched for the fan resister or MOSFET to die too.
