Engine light came on?????
Old Jul 8, 2008 | 09:54 PM
ELSALV39's Avatar
Default Engine light came on?????
What you know, the engine light came on. The carhas only got 700 miles. I took it the dealer and was told that it was glitch in the computer system. They did all kind of tests and found no issues. I was not charged for it but Im kind of troubled about it. Any input would be appreciated.
Old Jul 9, 2008 | 03:57 PM
sstlaure's Avatar
Default RE: Engine light came on?????
When the CEL (Check Engine Light) goes on, a code has been tripped in the system. What code was showing?
There are tons of things (both minor and major) that can trip the CEL (including just not tightening the gas cap after filling up)
I'd try to get the code from the dealer to understand what code was showing.
Old Jul 9, 2008 | 04:18 PM
ELSALV39's Avatar
Thank you. I will ask the dealer about the code.
Old Jul 9, 2008 | 05:55 PM
I would be too Luis.
Theyneed to find the cause and as long asthe PCM/ECU was not reset,the problemshould be held in the it's memory. If they are telling you they can't find anissue, they are lying.
I recently had an ongoingCEL (sometimes called an MIL in Mazda-speak) that was tied to several issues. All were covered under warranty...+$900 (including 3 days and 2 '08Mazda6i VE loaner cars) charged back to Mazda.
'Sure glad I didn't have to pay that!!
Old Jul 10, 2008 | 11:25 AM
ELSALV39's Avatar
The car is acting up weird. see if i can explain myself better-when the car is in idle - like at a stop light. I can feel a jerking motion within the car. But the rpm needle does not move or go up and down. also, the a\c can be on or not. so it has nothing to do with the a\c- I believe. Again, the dealer said that they found no issuesand that the engine light went on because of a computer glitch. shouldI take it back and have them look into it deeper?
Old Jul 10, 2008 | 07:22 PM
Have them look at the engine mounts, especially #3.
They may also need to re-flash the PCM.
Look at the list of TSBs availableto see if any seem to fit your symptoms. If so, print out those and "suggest" that these may be involved w/your issue.
Of course, these are all just guesses and recommendations on my part. Pleasedo not go to your dealer and demand that they do all of these repairs w/o checking first.
Old Jul 10, 2008 | 08:52 PM
vegasguy's Avatar
I have been experiencing the check engine light issue as well. I took my mazda6 to the dealer a few months back due to an emissions recall which they said was causing the check engine light to come on. However it has started to reappear recently. Everytime I reset the gas cap after 8-10 starts it goes out for about 4-5 days then reappears. Has anyone else ever experienced this? Could the gas cap be going bad, I have noticed that it backs off
Old Jul 11, 2008 | 10:11 AM
ELSALV39's Avatar
Richard, I understand what you are saying. Thank you for the help and input. vegasguy- I believe I might be having the same issue. I will be in Vegas this weekend. HOT HOT!!!
Old Jul 11, 2008 | 12:57 PM
Vroom_Vroom84's Avatar
are you pumping gas every 4-5 days? maybe you're not tightening the cap enough/locking the cap - if it has a lock.
Old Jul 11, 2008 | 02:28 PM
vegasguy, You may be experienceing a problem related to the fuel purge valve (check valve) on the tank itself. It can cause issues that appear to be gas cap related.
