Engine Got Wet - Check Engine Light Stays On
I have a 1999 Miata and I was cleaning under the hood and apparently I went overboard. The engine got some water on top of the block and when I restarted the car it sputtered at first but after a couple minutes it seemed to run fine.
While it was misfiring the check engine light came on and now it will not shut off even after I have driven it close to an hour.
The car only has 28,000 miles on it.
1. Turn the courtesy light on (leave a door open).
2. Disconnect the battery negative cable from the battery.
3. Wait apprx. 30 secs. and reconnect battery.
Start engine, do a little drivearound, see how things go. You will have to reset your clock and radio station tuning presets.
issokivi
Apr 12, 2013 12:59 AM
sixthsense
Nov 22, 2009 08:15 AM
