A/C problem in the Arizona heat with my MPV
Old Jul 19, 2011 | 11:39 AM
EdgarMazda's Avatar
Default A/C problem in the Arizona heat with my MPV
I have a 2003 Mazda MPV v6 w/ front & rear a/c (I bought it new, this is a new problem).
Its not consistent but most of the time the front a/c does not blow like it should.
It does blow cold air all the time but it barely reaches the driver and front passenger when it’s on high (#4 setting) has anyone encounter this problem with this minivan?
I would like to know if anyone knows where I should start from?
Your help is greatly appreciated.
Old Jul 20, 2011 | 05:04 AM
Master P's Avatar
Hi, I would start at the pollen filter first , Make sure its not blocked please. A blocked Pollen filter will cause a restriction in Air flow. Also make sure that the Air vent pipe is secure against the blower unit housing , If this pipe comes adrift it will cause poor air circulation to the vents hence a loss in cold air. Hope this helps.
Old Jul 21, 2011 | 05:56 PM
EdgarMazda's Avatar
Thanks Master P, thats what it was....
My Brother, the owner of the mini van hadn't been able to find it so he thought it might not have one. But I took it apart this morning till I found it right behind the glove box. Now you need goggles to drive this mini van, it blows cold and hard, it'll dry your eyeballs out.
Thanks again.
Z28_Mazda_B5000
Aug 20, 2024 11:42 PM
EdgarMazda
Jul 19, 2011 10:57 AM
gantw
Jun 27, 2008 10:03 AM
gantw
Mar 3, 2006 12:34 PM
gantw
Feb 23, 2006 01:24 AM
