a/c-heat fan problems
Old Aug 13, 2007 | 12:12 PM
toddhigh's Avatar
Default a/c-heat fan problems
hey i have a 05 mazda3 2.0L. the fan for ac and heat doesnt work all the time. sometimes it turns on right away other times it wont turn on for 45 mins after driving. whether ac on or off the fan doesnt work properly. its an intermittent problem but most of the time takes forever to turn on. please help me, i dont like driving in a sauna...
Old Aug 17, 2007 | 09:37 AM
maverick_ggm's Avatar
Default RE: a/c-heat fan problems
You can startwith replacing the blower motor resistor. The part is only about 20 bucks, so it's a cheap method of trial and error, although installation might be a little pricey if you're not doing it yourself. You can also bring it in to a dealer and they could check it out, there's a good chance it's still under warranty.
Old Aug 17, 2007 | 12:30 PM
toddhigh's Avatar
thanks, i will check that out
Old Sep 5, 2007 | 09:15 AM
toddhigh's Avatar
where is the blower resistor located on 2005 mazda 3i 2.0?
Old Sep 6, 2007 | 04:25 PM
hixx's Avatar
If the fan does not work at all i usually bang on the bottom of the fan with my hand first. If it starts running then the brushs in the motor are usually the culprut. That circuit has a circuit breaker in the fuse panel instead of a fuse also. They can go bad but it's uncommon.
parcou
Jul 15, 2013 09:39 PM
usafvet
Oct 8, 2008 05:01 PM
egoldsworthy
Dec 18, 2007 08:50 AM
Psychofly
May 27, 2007 08:23 PM
6GuyInAZ
May 18, 2006 02:05 PM
