5th Gear Jumping Out
Old Jan 20, 2008 | 01:26 PM
rrdo's Avatar
Default 5th Gear Jumping Out
Hello,
Got a 1997 Protege, 5-speed. When I shift into 5th gear, it keeps popping out (I can hold it in 5th if I push on the shifter). Took off transmission cover for the 5th/reverse gears and replaced the synchros (2)and 5th/Reverse clutch hub assembly. Did not correct the problem. I am now starting to think it is the 5th gear itself. The teeth in the 5th gear where the clutch hub assembly engages, looks a little worn. All other teeth look fine. Could this be the problem? Not sure of the tollerance?
Inspection of the shift linkage looks normal. I am scratching my head on this. Any help would be greatly appreciated.
Thanks,
David
Old Jan 28, 2008 | 08:45 AM
rrdo's Avatar
Default RE: 5th Gear Jumping Out (UPDATE)
Hello Everyone,
Just wanted to provide an update to my problem. We changed the 5th gear itself and that solved our problem. Our guess is a lazy driver probably accidentally pulls the shifter out of 5th too many times without clutching and over time, wears out the 5th gear teeth that engage with the 5th/Reverse Clutch Hub Assembly (we are just guessing). When we compared the new 5th gear with the old 5th gear, the wear was very noticeable.
Again, just wanted to post in case this helps anyone else. By the way, the 5th gear is very accessible without having to drop the transmission. Easy change.
David
mattpharding
Mar 11, 2023 10:01 AM
wayne Sangwell
Mar 13, 2015 07:39 PM
brokenfish
Dec 18, 2012 03:14 AM
Stotty
Nov 9, 2010 01:14 PM
rrdo
Jan 28, 2008 08:45 AM
