2004 mazda 6 v6 surging idle
Old Feb 20, 2012 | 11:59 AM
Awesome.
Old Jun 9, 2013 | 09:51 PM
Zmaiter's Avatar
Default Can I do this fix?
Originally Posted by cgladish
problem solved! it turned out to be the top hose from the IM that connects to the
second hose ( that in turns connects to the pcv valve ) had a hole in it.
weird in that it looked like the hole was a result a something rubbing against it, but nothing was close it. the hose also felt to be pretty thin too.
anyways, swapped it out & back in business!
thanks for the help!
That is amazing. I am having the exact same issue and the mechanics keep telling me they do not know what this is. I am not a mechanic but definitely handy. Is this a fix I should be able to do myself? I am assuming IM is Intake Manifold. As long as there is nothing major being removed I should be good. Thanks.
Old Jul 5, 2013 | 01:02 PM
cgladish's Avatar
i haven't look at this post in awhile, but just now came across your note.
if you have the same problem that i had ( blow PCV hose ), this was a 1 minute fix.
the only other issue i came across since then was the sequential replacement ( over a +/- 6 month period ) of each coil pack( 6 total ). this threw a cel code ( i.e. P0301, P0303 ). depending on which one went out, determined how hard it was to fix. if it's any of the front located packs, then just removing the engine allowed access to the coil packs. if it's any of the back ones, then you need to remove the intake manifold too, along with the air intake hose, throttle body, egr valve.
not a hard job ( 30 - 40 min. ), but a pain in the axx.
lastly, if you replace any of the coil packs, i suggest going to any local auto parts house. they are have the price ( $65-$70 vs $140 @ mazda ).
good luck!
Old Aug 1, 2013 | 11:18 PM
vicdan's Avatar
in most cases is the air bypass valve
If you can't find it, go the dealer and look into the computer on the parts section
You can get also a free print out
Old Dec 28, 2019 | 07:32 PM
tstape's Avatar
I found a crack in the ribbed part of the pcv air intake hose (if you zoom in on the ribs you can see the crack). I did a temp fix with gorilla tape until my new one arrives in the mail. I cleared the 'running lean' codes and the check engine light has remained off.
karlp
Apr 5, 2017 08:27 PM
Wetwilly66
Jun 22, 2014 03:04 PM
Wetwilly66
May 7, 2014 09:33 PM
MP3me
May 19, 2010 07:31 PM
tye
Nov 7, 2009 09:34 PM
