1992 B2600i goes dead.
I have a 1992 B2600i that goes dead as I go down the road. It will turn over but not start. After a few minutes I hear a click and it will fire up. Any suggestions on what this could be?
Are you getting voltage INTO the coil when this happens? Is this a carbed engine? I would say its injected with the i at the end but not sure, the Japanese ran carbed engines much longer than most did.
There should not be a condenser on this car, condensers were only used on points ignition to keep the points from burning up. If you have a bad part it wouldnt hurt to replace it anyways, can you get a picture of the broken part?
Truck still only runs for a little while then quits...wait about 20 minutes then starts up again... If you bump the starter you hear a click when you release it.. If you hear the cick it while start up.. I think the click is coming from the box just above the fuel pump relay.. Anyone know what that is?
Cartel
May 30, 2015 06:21 PM
little dutch
Apr 11, 2015 01:04 PM
92mazdaman
Nov 13, 2006 02:13 PM
