04 mazda 6: white smoke problem, help!
hi guys need some help
my gf has a 2004 mazda 6 and she started to have problems with it... it trowing out white smoke out the exhaust (a lot). it has 100,000 miles and the check engine light on. i was going to start with giving the car a tune up ( spark plugs, wires, intake filter, maybe the O2 sensors) what else should i do? clean the injectors? thanks
i just had a white smoke on starup & while accelerating mazda 6 3.0l that had bad valve guide seals. i had to remove the cylinder heads & inspect the entire motor. all i found was # 2 & # 5 exhast valve seals leaking but we replaced all of them since we were there. the car has not had any problems since.
i have not seen any head gasket problems with the 3.0l yet. but to pull the heads of & inspect the valves you typically have to remove the heads which means the head gaskets are going to be replaced.
ORIGINAL: jdmmanny
arprok13
Dec 2, 2013 05:52 AM
