-   Electronics, Computer & Fuel Systems (https://www.mazdaforum.com/forum/electronics-computer-fuel-systems-39/)
-   -   headlight fail (https://www.mazdaforum.com/forum/electronics-computer-fuel-systems-39/headlight-fail-15461/)
mazdacreep Aug 21, 2008 02:37 AM
headlight fail
newbie here.. how would the low beam headlights on a 1999 Mazda fail?..dont have enough idea for this..i want to repair it myself..
_________________
mazdacreep6576232
mazdacreep Aug 21, 2008 02:51 AM
RE: headlight fail
I had that problem once. I found out that lights fail due to a faulty switches on the steering wheel console. So i pull it apart and clean up the contacts. good luck..
tnx..dats a good point
virgin1 Aug 22, 2008 12:58 PM
RE: headlight fail
Could also be a bad connection to/at the relay or a bad relay too. Sometimes the internal contacts of a relay get dirty or burned and fail. I would check for power there first. If you have power but no lights you know it's the relay. If not, probably the switch assembly.
leftright Aug 28, 2008 04:34 PM
RE: headlight fail
headlidgt is easy to replace, open hood turn app 1/4 way pops right out . when installing new bulb first wipe with rubbing alcohol when installing don't touch with fingers use gloves (oil in hande causes failure.
