Electronics, Computer & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
Crank position sensor fault
Old Oct 1, 2007 | 05:15 PM
bhs5466050's Avatar
Default Crank position sensor fault
1996 626 - standard transmission. It is showing an engine light on the dash. Fault code generated indicates a 'crank sensor error'. The crank sensor, sensor bracket and sensor wiring to onboard PC have all been replaced. On-board PC verified ok. Tolerances have been measured and fall well within specs.
Driveability is good (other than the lighted engine prob on the dash!). Any ideas on what to focus on next????
Old Oct 2, 2007 | 06:28 PM
hixx's Avatar
Default RE: Crank position sensor fault
Possibly a crack in the reluctor or PCM fault. When you erase the code does it come back immediately?
Roland
Oct 31, 2012 03:27 AM
plaidman
Aug 28, 2011 10:35 AM
dogg123452
Nov 8, 2010 06:03 PM
_Mike_
Sep 17, 2005 04:05 AM
snapring6r
Apr 25, 2005 07:42 PM
