-   Detailing (https://www.mazdaforum.com/forum/detailing-41/)
-   -   Protecting Rubber Door Seals (https://www.mazdaforum.com/forum/detailing-41/protecting-rubber-door-seals-10811/)
protegedon Oct 6, 2007 12:48 PM
:eek: Wanted to get some opinions on protecting the rubber door seals on my 2003 Protege. I usually clean them with a rag moistened with a weak solution of water and rubbing alcohol and then apply Armor All once they are dry. This seems to work quite well. I recently read that silicone spray works well for this purpose and am considering using that instead of the Armor All.
Over the years, I've heard a lot of bad things about Armor All, but I haven't seen test data that demonstrates that it isn't a good protectant of rubber and vinyl. I often wonder whether these negative opinions might be nothing more than rumors spread by the manufacturers of competitive products.
virgin1 Oct 6, 2007 08:49 PM
RE: Protecting Rubber Door Seals
Silcone spray is easy and works the best to keep them pliable and from sticking to metalin cold weather.
That's what I would recommend.
And I have had personal bad experiences w/Amour-all and do/have not recommended it for many years now... But I do like their gel-tire dressing.
