Detailing Discuss detailing your ride inside and out here.
Protecting Rubber Door Seals
Old Oct 6, 2007 | 12:48 PM
protegedon's Avatar
Default Protecting Rubber Door Seals
Wanted to get some opinions on protecting the rubber door seals on my 2003 Protege. I usually clean them with a rag moistened with a weak solution of water and rubbing alcohol and then apply Armor All once they are dry. This seems to work quite well. I recently read that silicone spray works well for this purpose and am considering using that instead of the Armor All.
Over the years, I've heard a lot of bad things about Armor All, but I haven't seen test data that demonstrates that it isn't a good protectant of rubber and vinyl. I often wonder whether these negative opinions might be nothing more than rumors spread by the manufacturers of competitive products.
Old Oct 6, 2007 | 08:49 PM
Default RE: Protecting Rubber Door Seals
Silcone spray is easy and works the best to keep them pliable and from sticking to metalin cold weather.
That's what I would recommend.
And I have had personal bad experiences w/Amour-all and do/have not recommended it for many years now... But I do like their gel-tire dressing.
Gunsmoke
Jul 17, 2011 10:37 PM
Alpha Wolf
May 3, 2007 05:00 PM
H15A5H1
Apr 6, 2007 09:45 PM
UrbanmanUSA
Mar 8, 2007 12:56 PM
HEFFAE
Aug 18, 2006 12:42 AM
