Annoying dash lights
I would appreciate hearing form anyone who has figured out how to disable the annoying bright blue high beam indicator and red tachometer lights on the tach dial face. As well as turning the main instrument lights down even more than the factory settings.
Thanks
Thanks
oneamous, What car do you have?
If the electroluminecent dash lighting, have you tried the push-button switch on the upper left, between the tach and speedo? If you're only using the rheostat, you're right, it doesn't do much.
Check you owners manual for further instructions.
Also, the "annoying bright blue high beam indicator" is going to be a requirement for state inspection.
jpaschal21
06-17-2009 06:56 PM
anthonytsi
11-12-2008 04:37 PM
Bluehelmet
08-10-2005 09:09 PM
