Annoying dash lights
Old 10-16-2014, 01:01 PM
oneamous's Avatar
Default Annoying dash lights
I would appreciate hearing form anyone who has figured out how to disable the annoying bright blue high beam indicator and red tachometer lights on the tach dial face. As well as turning the main instrument lights down even more than the factory settings.
Thanks
Old 10-28-2014, 05:30 AM
goldsworthy's Avatar
Take the bulb out or cover the lit area with black tape (classy)
Old 10-29-2014, 10:12 AM
oneamous, What car do you have?
If the electroluminecent dash lighting, have you tried the push-button switch on the upper left, between the tach and speedo? If you're only using the rheostat, you're right, it doesn't do much.
Check you owners manual for further instructions.
Also, the "annoying bright blue high beam indicator" is going to be a requirement for state inspection.
Ransack
06-23-2022 09:43 PM
jpaschal21
06-17-2009 06:56 PM
anthonytsi
11-12-2008 04:37 PM
Patrick
10-08-2005 07:40 PM
Bluehelmet
08-10-2005 09:09 PM
Quick Reply: Annoying dash lights
