Fuse location...
Old 07-15-2007, 09:03 AM
Manewzda's Avatar
Default Fuse location...
Hi. I was wondering if anybody knew where I can get info on fuse location for a 2006 '06 s? I would like to located, in particular, the fuse for the keyless entry. However, it would be nice to know what fuse is for what. Thanks for the help!
Old 07-15-2007, 09:35 AM
sstlaure's Avatar
Default RE: Fuse location...
There should be a diagram inside your owner's manual.
Old 07-15-2007, 11:29 PM
Well there are two fuse boxes on the mazda 6. I belive the one for the stereo and lights and etc is left of the pedals. You just have to pull off alittle plastic tab that says fuse box. Also the other one is under the hood next to the battery. The top should just pop off. I couldnt tell you which fuse is which, check your manul for the wiring diagram.
Old 07-16-2007, 04:26 AM
Since were talking about fuses, I got my V1 plugged into my cigarette lighter. Everytime I hit a bump in the road, or shift, my V1 will turn off and then back on. Could this be the fuse was short circuited when I installed my CAI and now I need to just put a new fuse in?
Old 07-17-2007, 01:22 AM
i would imagine its a fualty wire because how it goes on and off. Id check and make sure all connections are made cleanly and the fuse is put in all the way.
Old 07-17-2007, 04:55 PM
Besides the owners manual, most fuse box covers have the diagram imprinted on their surface. Some are difficult to read because it's just raised plastic of the same color as the cover.
Old 07-17-2007, 07:35 PM
babyhuey's Avatar
Some of the fuses supply power to a lot of different systems and not just one so is close to impossible to list what each fuse would go to.
If you have the Advanced keyless entry with the credit card sized remote then the following fuses would supply power to the system module. 15 Amp ROOM, 15 Amp ENGINE, and 5 Amp MIRR.
If you only have the standard keyless system then only the 15 Amp ROOM fuse is involved.
All of these fuses are in the underdash fuse box on outer side of drivers footwell.
Buck Mulligan
02-15-2012 11:19 AM
robwats83
06-27-2011 04:37 PM
kasper
01-04-2006 01:11 AM
khaosx2005
11-09-2005 08:45 PM
qisoftware
09-07-2005 03:28 AM
Quick Reply: Fuse location...
