Mazda 5 Strut Problem?
Old 02-17-2013, 02:18 PM
ggsumo's Avatar
You beat me to it. They wont wear out but will sound like you've got mice :-)
Old 02-17-2013, 11:17 PM
slbenz's Avatar
NOPE.
Poly Bushings need lubrication almost yearly or they will squeek. First pic is poly, second one is rubber.
There are two broad categories of bushings: those that rotate and those than remain stationary. The rotational bushings should be rubber. The sway bar bushings are in the rotational category!
Rubber bushings are always appropriate. Polyurethane should be kept to bushings that do not move. Due to rubber's unique characteristics, it may feel quieter and smoother than polyurethane. This is a natural phenomena and does not necessarily mean that rubber has worse performance characteristics.
From: Bushings: Rubber vs. Polyurethane - Subaru Impreza WRX STI Forums: IWSTI.com
poly bushing are great if you want to have a stiff suspension and plan to drive the car hard. The down side is the poly bushings are hard and do not absorb road shock like rubber bushings. That means the shock is transmitted through the suspension to the body. Poly bushings also have a tendency to squeak.
In sway bar mount applications, most squeaking comes from not cleaning the sway bar prior to installing the bushings and not using our “squeak proof” grease!
The original rubber bushing or mount was fairly soft which helped to attenuate noise and vibration that is generated by the tires and road surface. Increasing the hardness of the bushing either with harder rubber, urethane or even bronze, will allow more transmission of noise and vibration. Some manufacturers formulate the hardness and design to reduce this effect. A softer urethane bushing allows the vehicle to perform better without the harshness, even over the same hardness rubber piece.
Guess it depends on what you got and how you installed them.
ClickMe
for proper install grease
Good luck.
Thanks for sharing but if I have to grease them once-a-year then that is not a problem. The new poly bushings have a grease port. After installing them today, I don't hear any more noise and they definitely help with the handling of the Mazda 5. Now just waiting for the rear shocks then the major components to the suspension have been replaced. By the way, the old bushings were badly cracked in several places and was extremely soft.
Old 11-17-2016, 03:32 PM
britd88's Avatar
Default shocks on mazda
I have a 2010 Mazda 5 and have had many issues with back shocks but it's not the shocks themselves it's the upper back mount that keeps breaking it's a 23.00 part at hole works and decently easy to fix...and $26.00 at auto zone
ofthegrave
04-28-2015 03:56 PM
dfz1
05-26-2014 09:29 AM
rikabs
08-24-2013 08:53 PM
Spaz218
02-24-2006 11:03 PM
Vettman 1
02-18-2006 01:37 PM
Quick Reply: Mazda 5 Strut Problem?
