Really!? the exhaust mod
Old 08-18-2011, 06:42 PM
Jono-3000's Avatar
Default Really!? the exhaust mod
So after some investigation regarding opeing up the exhaust on my 08 3 2.3 5sp, I find there are three in line exhaust systems; pre-cat, cat and silencer(only had the car less a week). And that the rear suspension is bolted up on top of the rear portion of the exhaust? Man sakes alive! They couldn't make it any easier could they? Anyways I am looking forward to losing the 3 cat exhaust and restrictive muffler sooner than later!
Old 08-19-2011, 02:29 PM
You'll be sorry.....
Along with the restriction you will lose and the noise you will gain, you will also lose nearly all of your low-end torque.
Some restriction is necessary. I suggest you keep the legal parts of the exhaust (pre-cat and cat) alone, at least. Also, running w/o a resonator will drone you and your passengers to death.
Go with an upgraded (re: noisier) muffler in the stock location if you will, and maybe a better tailpipe tip (e.g. 4" double-walled stainless steel) and leave it at that. You'll be much happier with the results.
Old 08-20-2011, 07:49 AM
shipo's Avatar
As Richard wrote, performing the changes you've outlined above will most likely produce a very undesirable result; just follow the KISS principle and either leave your car alone or follow the changes Richard suggests.
Old 08-20-2011, 02:27 PM
mzdaspd304's Avatar
Agreed to both above. And trust me, Ive messed with this exhaust enough to know. I did 2.5" "catback" have a Thrush glass pack muffler, OBX resonator down pipe with the stock header with cat. Its plenty loud enough and doesn't ruin your low end.
Here are some vids of pretty much before and after:
This one is with the header w/o the cat and no restrictions besides the glasspack:
mzdaspd304's Channel - YouTube
This one is without the header:
Old 08-26-2011, 12:10 AM
Jono-3000's Avatar
Thanks yea you're right, I still haz warranty, I may go with Magnaflo, they're a good name or remus. Remus is big $$ Thanks guise and vid was very entertaining I will wait till the warranty is gone and mod the **** out of her!
Old 08-30-2011, 08:23 AM
Dang, Mike!! 'Bet you're pissing off some neighbors w/that system.
It sounds incredibly loud on my system even w/the volume turned down.
yawnie_DELETEDBYREQUEST
07-07-2006 02:04 AM
87 turbo II
06-07-2006 02:10 AM
Alucard
03-22-2006 01:04 AM
johndeere
09-09-2005 06:48 PM
Quick Reply: Really!? the exhaust mod
