HELP P0401 3.0 EGR checks ok
Old 07-27-2014, 05:07 PM
Ruff1's Avatar
Angry HELP P0401 3.0 EGR checks ok
When I pull vacuum on new EGR engine stutters therefore it seems good. I have 12v at solenoid and 45 ohms across pins which I read is good, any suggestions on next thing to ck? Thanks
Old 07-27-2014, 06:22 PM
According to: OBD-II Trouble Code: P0401 Insufficient EGR Flow
Copyright © OBD-Codes.com
Causes:
A code P0401 most likely means one or more of the following has happened: The DPFE (differential pressure feedback EGR) sensor is faulty and needs to be replaced, There is a blockage in the EGR (tube), most likely carbon buildup,
The EGR valve is faulty The EGR valve may not be opening due to a lack of vaccuum
Possible Solutions
In fixing this code, it is quite common for people to just replace the EGR valve only to have the OBD code return. The EGR valve is not always the culprit. Use a vacuum pump and pull the EGR valve open while monitoring engine RPM's & DPFE voltage. There should be a noticable difference in RPM's with the EGR open
Clean out the EGR valve and/or tubing to remove deposits Check the voltage at the DPFE, compare to specified values (refer to a repair manual for your specific model)
Replace the DPFE sensor (with a good quality / OEM one)
Replace the EGR valve
I can't help you with specific values!
Old 07-27-2014, 08:28 PM
Ruff1's Avatar
Thank you, someone has already replaced the EGR and RPM's do drop with vacuum applied to the EGR so I am suspecting DPFE.
Old 07-27-2014, 08:31 PM
Ruff1's Avatar
The PCV (100,000 mi) has never been replaced is it as easy as it looks to place, do you have any thoughts?
Old 07-28-2014, 07:38 AM
Thumbs up
Replace it !
Mazda never does!
Make sure you line up tabs!
It turns in, not push in.
I just ordered a new one for my car, last changed in 2011! and I have low mileage! Ever clean your throttle body or MAF! Try it it might like it!
Last edited by UseYourNoggin; 08-01-2014 at 08:02 PM. Reason: PCV ordered, throttle body
Old 07-29-2014, 05:51 AM
Ruff1's Avatar
Thanks, I took it to get state inspected but they said I have to drive it now after I reset ck engine light.
mazdagirl8
09-22-2011 01:30 PM
moshmike
03-24-2011 03:32 PM
rapala77
01-07-2011 06:24 PM
Art
12-17-2010 09:27 PM
shopgirrrl
09-24-2009 04:46 PM
Quick Reply: HELP P0401 3.0 EGR checks ok
