Vacuum leak?
Old 11-16-2007, 10:54 PM
dkofoed's Avatar
Default Vacuum leak?
I'm wondering if I have a vacuum leak ... I have an 88 mazda b2200 which shakes a bit when idling. Seems to shake a bit more when in gear and idling as opposed to put in neutral (it's an automatic transmission). Does that sound like a vacuum issue - or something else?
I also failed an emissions test recently which apparently could also be vacuum related.
If it does sound like a vacuum leak problem, are there any relatively easy ways to check where the leak is coming from?
Old 11-16-2007, 11:06 PM
Default RE: Vacuum leak?
i wouldnt real out a vacuum leak and to find it you can start the truck and try to hear it or you can feel around for it but two questions what rpm does it idle at and is the air cleaner on it
Old 11-16-2007, 11:17 PM
dkofoed's Avatar
Sorry, what would a vacuum leak sound like? also, how would you "feel" it? maybe some air flow around the hoses?
Old 11-17-2007, 07:02 PM
to hear it you would listen for a hissing noise and to feel it you look for open hoses or feel and follow hoses it see if any are disconected the feel of an open hose if it has vacuum on it is it will stick t oyour finger or of course you will feel air if you are close to it
Old 11-19-2007, 01:26 PM
easier way of testing would be an unlit propane torch and run it over all of the vaccuum hoses and fiting adn around the bottom of the carb to see if it idles higher. If it does then theres your leak.
unsplosion
09-22-2013 08:30 PM
ghs215
11-11-2011 01:24 PM
kirk98s
02-10-2009 08:15 AM
sherrid36
06-13-2008 10:19 AM
AUTOMaNs
04-04-2008 05:58 PM
Quick Reply: Vacuum leak?
