B2600i Cracked Block??
Old 03-03-2008, 12:11 PM
mxer201's Avatar
Default B2600i Cracked Block??
I did a post about what I thought was a bad freeze plug. Well I think it might be a hair line crack in the block. On the back side of the water pump there is a tube formed in the cast of the block. The side of this tube was damp with coolant. If there is a crack it is so small that is only seeps very slowly but enough to run down to and past the freeze plug. According to coolant flow diagrams coolant flows from the water pump through this tube into the block. I cleaned the area with fine sandpaper and then steel wool. Then I spread a coating of Epoxysteel over the area in question. I did this several days ago and I THINK it might be fixed. Just wondering if anyone ever experienced a problem in this area of the block?
Old 03-04-2008, 07:53 AM
Default RE: B2600i Cracked Block??
I haven't experienced this problem but I have heard of the coolant inlet pipe cracking. I'm not sure if these models have a particular problem with this or not.
Old 03-04-2008, 09:26 AM
sstlaure's Avatar
You could also try an internal block/head sealant.
http://www.motorshop1.co.uk/sealup.htm
hugh2293
09-29-2009 07:37 PM
acflye
04-15-2007 12:51 PM
mazda_roller
03-12-2007 11:25 PM
mcoplin
08-11-2006 11:42 PM
Metric
07-05-2006 11:26 AM
Quick Reply: B2600i Cracked Block??
