B2200 check engine light
Old 01-29-2015, 12:36 PM
Mr_Leffe's Avatar
Default B2200 check engine light
Hello... My '88 B2200 pick up check engine light stays on a few minutes after start up and comes on when coasting down hill ( no throttle but still in gear).
Also where is the socket to plug in the code analyzer? Thanks for your replies..
Old 01-29-2015, 12:50 PM
hixx's Avatar
There is a single green 1 pin connector near the wiper motor. Jump it to ground and count the check engine light flash's 1 long flash = 10. 1 short flash = 1
Old 01-29-2015, 01:34 PM
Mr_Leffe's Avatar
Default Flashes
Thanks.. I have found the little single socket. It is white.
There is a 3 pin connector nearby that has been disconnected.
Where would I find what the # means?
Old 01-29-2015, 01:40 PM
hixx's Avatar
I can tell you. What's the code? There are only 16 codes.
Old 01-29-2015, 02:00 PM
Mr_Leffe's Avatar
How will i recognize a specific #? Like 14.. How will I know a #4?
Old 01-29-2015, 02:07 PM
hixx's Avatar
4 short flash's = 4
4 long flash's = 40
Old 01-29-2015, 03:12 PM
Mr_Leffe's Avatar
It's showing code # 16
Old 01-29-2015, 03:18 PM
hixx's Avatar
EGR position sensor.
Old 01-29-2015, 03:21 PM
Mr_Leffe's Avatar
How to fix??
Old 01-29-2015, 03:38 PM
hixx's Avatar
If you have no vacuum leaks,it is plugged up and no wiring problems or driveability problems i would replace the EGR position sensor and clean the EGR valve.
Quick Reply: B2200 check engine light
