'93 B2600i 4x4 problems
Old 05-13-2014, 09:32 PM
Jaff77's Avatar
Default '93 B2600i 4x4 problems
Truck starts and idles fine, but when I put it in gear and try to accelerate, it has no power. I've changed the fuel filter, fuel pump, spark plugs, distributor, coil, coil wire, plug wires, even the carb assembly. What else could it be?
Old 05-14-2014, 07:52 PM
nhtrib's Avatar
Send a copy of your post to support@avproecm.com. My 92 b2600 had the EXACT problems yours does. They fixed mine 3 years ago, and it has been fine. I highly recommend this company. Check out their web site also.
Old 06-11-2014, 08:54 PM
Pantharen's Avatar
Carb Assembly??? any Mazda truck built after 1988 didn't have a carb, they're all EFI..
Anyways, your problem is the either the ECU is on its way out, or you could have a plug cat converter, or your timing is out..
Check out this forum that is dedicated to nothing but Mazda Trucks: Mazdatrucking.com Forum
mjarvis0103
10-20-2022 05:40 PM
xtrigger
08-18-2006 06:07 PM
TRUCKSTER
07-29-2006 02:11 PM
Btruckr
08-16-2005 01:16 AM
Btruckr
06-10-2005 03:43 PM
Quick Reply: '93 B2600i 4x4 problems
