1992 Mazda b2600i fuel problem
Old 01-31-2012, 01:08 PM
rtmastertech's Avatar
Originally Posted by 77amc
Did you find out the problem..?
I'm working on a friends auto 2600i P/u and it just went out. Turns over but not starting. I'm thinking it's the distributor or ECu.
I pulled the pump and tested it and it works fine, and has a half tank.
The shops around here didn't say that there was a relay, but knowing F/I there's got to be one somewhere. Another friend said that the ECU controls the pump.
Any answers.. Let me know.
E
sounds like an ecm problem.i am working on a 93 2600i,i have been all over this truck.it started with a cold no start and got worse.i got a ecm out of my bosses wrecked truck plugged it in truck runs like a sewing machine again.
fuelpressure spec is 28-37 psi with 18-21 in vaccum to regulator hope this helps.if no luck let me know I will keep checking forum
Old 03-08-2015, 03:01 PM
nhtrib's Avatar
Go to this web site Mazda B2600i ECM-ECU Lifetime Warranty $190 and read about our trucks. They cured mine. I highly recommend them.
Old 07-23-2015, 11:13 AM
geterdun's Avatar
I bought a 93 B2600 extended cab running poorly last year (2014). It has 150 # compression, all cylinders. I changed it to a carb (I made the intake) and equivalent of '89 carbed engine distributor (altered 2200 distributor), runs great, will spin a tire on take off (automatic).
Now all I have to do is rewire the a/c as vehicles in the seventies were, no more bot worries.
anapee
06-04-2009 01:01 PM
fledermas
03-30-2008 12:16 PM
cayeb
12-20-2007 09:57 PM
IMPORTS
04-16-2007 06:11 PM
92mazdaman
11-13-2006 02:13 PM
Quick Reply: 1992 Mazda b2600i fuel problem
