1992 B2600I CAN'T KEEP RUNNING
Old 04-15-2007, 12:37 AM
IMPORTS's Avatar
Default 1992 B2600I CAN'T KEEP RUNNING
hi hoping someone can help 92 mazda b2600i will start but will not idle or rev up the only way it will run is with very slight pressure on gas pedal . if you give it more gas it dies if you let off gas it will die .
any ideas !!!!!!!!!
have replace o2 plugs cap rotor wires & coolant temp sensor, fuel filter also tried a diff dist assembly .
non of this helped
Old 04-15-2007, 03:39 AM
Tracker's Avatar
Default RE: 1992 B2600I CAN'T KEEP RUNNING
idle air bypass valve is faulty...needs to be replaced asap
Old 04-15-2007, 11:36 AM
IMPORTS's Avatar
IF THAT WAS BAD COULDN'T I STILL BE ABLE TO REV THE MOTOR UP ?
Old 04-16-2007, 06:11 PM
mxer201's Avatar
Has the ecm ever been repaired? Go to this link http://www.avproecm.com/
Then to the Print Postcard link at the bottom right. I had asimilar problem.This guy repaired the ecm and then it ran fine. Good luck.
stencil
08-07-2012 06:13 PM
Atlantabachelor
07-24-2010 12:09 PM
quinto555
08-20-2007 04:35 PM
92mazdaman
11-13-2006 02:13 PM
cchatoney
03-30-2006 11:05 PM
Quick Reply: 1992 B2600I CAN'T KEEP RUNNING
